I attempted to compile a basic program named Hello world using javac. However, when I attempted to run it using the command ‘java Hello’, the Java Virtual Machine (JVM) appeared to be incapable of interpreting the bytecode.
Result produced by ‘java Hello’:
Error: A JNI error has occurred, please check your installation and try again
Exception in thread "main" java.lang.UnsupportedClassVersionError: Hello has been compiled by a more recent version of the Java Runtime (class file version 57.0), this version of the Java Runtime only recognizes class file versions up to 52.0
        at java.lang.ClassLoader.defineClass1(Native Method)
        at java.lang.ClassLoader.defineClass(Unknown Source)
        at java.security.SecureClassLoader.defineClass(Unknown Source)
        at java.net.URLClassLoader.defineClass(Unknown Source)
        at java.net.URLClassLoader.access$100(Unknown Source)
        at java.net.URLClassLoader$1.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.net.URLClassLoader.findClass(Unknown Source)
        at java.lang.ClassLoader.loadClass(Unknown Source)
        at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
        at sun.launcher.LauncherHelper.checkAndLoadMain(Unknown Source)
Java is one of the most popular programming languages used by developers around the world. It is a versatile language that can be used to develop a range of applications, from desktop to web and mobile applications. Java code is compiled into bytecode, which is then executed by the Java Virtual Machine (JVM). However, sometimes the JVM may encounter errors when trying to execute Java bytecode. In this blog post, we will explore the error message “The JVM is unable to read the bytecode” and discuss how to resolve it.
Understanding the Error Message
The error message “The JVM is unable to read the bytecode” occurs when the JVM is unable to execute the Java bytecode. The error message usually appears when you try to run a Java application or an applet. The error message indicates that the JVM is unable to recognize the version of the bytecode. The error message also provides information about the version of the Java Runtime that is installed on the system.
The error message usually contains the following information:
– A JNI error has occurred, please check your installation and try again
– Exception in thread “main” java.lang.UnsupportedClassVersionError: Hello has been compiled by a more recent version of the Java Runtime (class file version 57.0), this version of the Java Runtime only recognizes class file versions up to 52.0
The first line of the error message indicates that a JNI (Java Native Interface) error has occurred. The JNI is a programming framework that allows Java code to interact with other programming languages. The second line of the error message indicates that the class file version of the bytecode is not recognized by the installed version of the Java Runtime.
Resolving the Error Message
To resolve the error message “The JVM is unable to read the bytecode”, you need to ensure that the version of the Java Runtime installed on the system is compatible with the version of the bytecode. The class file version of the bytecode is usually indicated by the number after the “class file version” in the error message.
For example, in the error message “Hello has been compiled by a more recent version of the Java Runtime (class file version 57.0), this version of the Java Runtime only recognizes class file versions up to 52.0”, the class file version of the bytecode is 57.0.
To resolve the error message, you can do one of the following:
– Upgrade the version of the Java Runtime installed on the system to a version that is compatible with the class file version of the bytecode.
– Use a version of the Java compiler that generates bytecode that is compatible with the installed version of the Java Runtime.
– Recompile the Java source code using a version of the Java compiler that generates bytecode that is compatible with the installed version of the Java Runtime.
Upgrading the Java Runtime
To upgrade the version of the Java Runtime installed on the system, follow the steps below:
1. Determine the version of the Java Runtime that is installed on the system. You can do this by running the following command in a command prompt or terminal window:
   java -version
2. Download and install a compatible version of the Java Runtime from the Oracle website.
3. Set the PATH environment variable to point to the directory where the new version of the Java Runtime is installed.
4. Verify that the new version of the Java Runtime is installed and working correctly by running the following command:
   java -version
Using a Compatible Java Compiler
To use a version of the Java compiler that generates bytecode that is compatible with the installed version of the Java Runtime, follow the steps below:
   java -version
2. Download and install a compatible version of the Java Development Kit (JDK) from the Oracle website.
3. Set the PATH environment variable to point to the directory where the new version of the JDK is installed.
4. Compile the Java source code using the new version of the Java compiler by running the following command:
   javac -target version source_file.java
   Replace version with the version of the Java Runtime that is installed on the system, and source_file.java with the name of the Java source file.
5. Run the Java application using the new version of the Java Runtime by running the following command:
   java class_name
   Replace class_name with the name of the Java class that contains the main method.
Recompiling the Java Source Code
To recompile the Java source code using a version of the Java compiler that generates bytecode that is compatible with the installed version of the Java Runtime, follow the steps below:
   java -version
3. Edit the Java source code to ensure that it is compatible with the installed version of the Java Runtime.
   java class_name
In this blog post, we have discussed the error message “The JVM is unable to read the bytecode” and how to resolve it. We have explored three methods for resolving the error message: upgrading the Java Runtime, using a compatible Java compiler, and recompiling the Java source code. By following the steps outlined in this blog post, you should be able to resolve the error message and run your Java applications and applets without any issues.
The error message, with any luck, is quite comprehensible:
up to 52.0
The compiler that you employed generated Java bytecode that is incompatible with your Java runtime (JRE) since the JRE is outdated (specifically, older than the JDK you employed for compilation).
During the process of compiling Java code, the compiler will generate Java bytecode. Various versions of Java bytecode exist (a new version of bytecode is typically introduced with each new Java release), and outdated JREs cannot execute bytecode if its version is too recent for them.
There are two potential solutions to this problem:
1) Use -target option
In theory, you have the option to resolve this issue by instructing the compiler to compile for an older JRE. You can do this by utilizing the -target parameter of javac (you can refer to the javac documentation for Java 9 for further details).
For instance, by executing:
javac -target 1.8 HelloWorld.java
you can compile bytecode for the JRE from Java 1.8 (also known as Java 8). This solution should eliminate the error you are encountering, as the bytecode version 52 mentioned in the error message corresponds to Java 8 (you can refer to the Java class file Wikipedia page for a table mapping bytecode versions to Java releases).
However, it’s worth noting that while this method may eliminate the error you are experiencing, you may encounter other issues relating to the Java API you are compiling against. In such cases, you would need to employ the javac option -bootclasspath or -release (if you are using Java 9 or newer).
2) Use matching JRE/JDK
If the first solution seems challenging, it’s because it is complicated :-).
The practical solution, particularly if you’re still in the learning stage, is to simply employ matching versions of the virtual machine/JRE and compiler. The easiest way to achieve this is by using the JRE that was included with the JDK download (that is, utilize java and javac from the same download).
By default, this is what should happen after you download and install the JDK. Therefore, the error you are encountering most likely indicates that you have an additional (or multiple) JRE installed elsewhere.
If possible, remove all JREs and JDKs except for the one JDK you intend to use. If you require multiple JREs to run in parallel, make sure that your configuration (e.g. PATH variable, IDE configuration, etc.) all point to the same JDK. This approach will help you avoid such issues.
Note that some IDEs (such as Eclipse) come with a built-in compiler – you may need to configure it separately to match the version of the JDK you have installed. Ideally, utilize the IDE with the JDK version recommended by the IDE.
