When you right-click on the Windows 10 start menu, a list of options such as “Apps & Features” and “Power Options” will appear.
For example, if you select “System,” the new window that opens will display the legacy System window (found in Control Panel > System) instead of the modern, tiled version.
Images:
I want this screen:
to open up rather than this screen:
Can this be done?
Askify Moderator Edited question May 4, 2023
