When enclosed in double parentheses, Incrementing a variable like (( var++ ))
it works in bash. However, I have found that it fails if the variable is set to 0 before like var=0
$ a=0 $ ((a++)) && echo "command succeeded" || echo "command failed" command failed $ a=1 $ ((a++)) && echo "command succeeded" || echo "command failed" command succeeded
Can anyone explain to me why this happens?
I am using gnome-terminal on Ubuntu Desktop 18.04.5 LTS.
Bash is a Unix shell and command language that is widely used in Linux and macOS operating systems. It provides a command-line interface for interacting with a computer system. Bash has several features that make it a powerful tool for scripting and automation. One of these features is the increment operator, which is used to increase the value of a variable by one.
However, there is a peculiar behavior that occurs when using the increment operator on a variable that has been set to 0. This behavior has puzzled many bash users, and in this article, we will explore the reason behind it.
The Increment Operator
The increment operator is represented by two plus signs (++), and it is used to increase the value of a variable by one. It can be used in two ways:
- Pre-increment: ++var – This increases the value of the variable by one before using it in an expression.
- Post-increment: var++ – This increases the value of the variable by one after using it in an expression.
The increment operator is commonly used in loops, where a variable needs to be incremented or decremented by a fixed value in each iteration. It is also used in conditional statements where a variable needs to be incremented or decremented based on certain conditions.
The Behavior of the Increment Operator on 0
When using the increment operator on a variable that has been set to 0, the behavior is not what one would expect. Let’s consider the following code:
The expected output would be “command succeeded,” but instead, the output is “command failed.” This behavior is due to the way bash handles arithmetic expressions. When bash encounters an arithmetic expression, it evaluates it using the C language rules for arithmetic.
In C, the value 0 is considered false, and any non-zero value is considered true. Therefore, when bash encounters the expression ((a++)), it evaluates it as follows:
- Evaluate the value of a, which is 0.
- Increment the value of a by one, so a is now 1.
- Return the original value of a, which is 0.
Since the original value of a is 0, which is considered false, the expression ((a++)) evaluates to false. Therefore, the command fails, and the output is “command failed.”
The Solution
To solve this problem, we can use the pre-increment operator instead of the post-increment operator. Let’s consider the following code:
$ a=0 $ ((++a)) && echo "command succeeded" || echo "command failed"
The output of this code is “command succeeded,” which is the expected output. This is because the pre-increment operator (++a) first increments the value of a and then returns the new value. Therefore, the expression ((++a)) evaluates to true, and the command succeeds.
The increment operator is a powerful tool in bash scripting, but its behavior on variables set to 0 can be confusing. The reason for this behavior is due to the way bash handles arithmetic expressions, which follows the C language rules for arithmetic. To solve this problem, we can use the pre-increment operator instead of the post-increment operator.
Understanding the behavior of the increment operator on variables set to 0 is essential for writing robust and reliable bash scripts. Hopefully, this article has shed some light on this issue and provided a solution to the problem.
The increment operator ((a++))
increments the value of the variable a
by 1. It works when a
is set to a non-zero value because the command succeeds and the echo "command succeeded"
statement is executed. However, when a
is set to 0, the increment operator increments the value of a
to 1, but the command itself fails.
In Bash, the double parentheses construct (( ... ))
is used to perform arithmetic operations and tests. It returns an exit status of 0 (true) if the arithmetic expression is non-zero, and an exit status of 1 (false) if the arithmetic expression is zero.
In the first example, you set a
to 0 and then try to increment it using ((a++))
. The increment operator increments a
to 1, but the arithmetic expression ((a++))
is still 0, so the command fails and the echo "command failed"
In the second example, you set a
to 1 and then try to increment it using ((a++))
to 2, and the arithmetic expression ((a++))
is non-zero, so the command succeeds and the echo "command succeeded"
To sum it up, the ((a++))
construct fails if the value of a
is 0 because the arithmetic expression ((a++))
is zero, and the double parentheses construct returns an exit status of 1 (false) for a zero arithmetic expression. If the value of a
is non-zero, the arithmetic expression ((a++))
is non-zero and the double parentheses construct returns an exit status of 0 (true).
According to the bash manpage, the return value of (( expression )) does not indicate an error status. Instead, the expression is evaluated according to the rules described under ARITHMETIC EVALUATION. If the value of the expression is non-zero, the return status is 0; otherwise, the return status is 1. This is exactly equivalent to let “expression”. For example, if I run ((a++)) and a
is initially 0
, a post-increment will be performed, so 1
will be returned, and then a
will be incremented. I can compare the results of post-increment and pre-increment by running the following commands:
$ unset a
$ ((a++)) ; echo Exitcode: $? a: $a
Exitcode: 1 a: 1
versus
$ unset a
$ ((++a)) ; echo Exitcode: $? a: $a
Exitcode: 0 a: 1
With pre-increment, a
will become 1
, and 0
will be returned.
